Kain
3/4 ton status
I have an issue with the trans jumping into neutral when you hit a hard bump.
I have tried to adjust it to not do it but no luck. Is there a trick to it.
Would it help to do it like a b&m shifter and put it in low then tighten the retainer bolt down? Kind of need to stop this when it jumps into neutral it usually hits 4000 rpms before i catch it.
