PsRumors
New one on me. Part of my new trans instructions are below and talks about shimming the torque converter.
this gap should be approximately 3/16” but no more than ¼”. (If the gap is larger than ¼”,
"The best way to be absolutely certain that the converter is fully indexed into the front pump is to place the
transmission/converter assembly up against the back of the engine. The bolt lugs on the converter should not be touching the
flex plate. There should be a gap between the flex plate and the converter bolt lugs. With the transmission bolted to the engine,
precision shims must be installed to
obtain the proper gap before the converter bolts are installed.)."
I have a gap of about 3/8s of an inch. I had just never heard of shimming a torque converter. Are there torque converter shims? Or just use a washer(s)?
