Shock Inboarding 101
I would have to agree about the Ford statement. I like i few of their trucks. granted I wouldn't go out searching for one. But the Excursion is BIG, and the newer F-350's are nice looking. (am I gonna get shot for that statement?? hahaha)
gmc4cw, thanks for clearing that up man. On screen it looks like a jab. I didn't want the thread to turn into one of those moronic argument threads that go on too long.
I have one more thing to say though.
If the inboarding kit comes with multiple mounts holes, play around with the angle of the shocks. There will be a "sweet spot" for your particular truck, and driving style. Like if your truck is manily a DD, you may prefer a more verticle setup, as opposed to a more angled setup. But as I said before (I think), TOO much angle will render most shock absorbers completely usless.
Kinda like adding another seventeen shocks to each axle. HAHAHA, okay that was a jab to show trucks. Sorry got off topic, I read too many of those scary steering things. hahaha. anyways, I ran out of sh!t to say. My mind is a raisin now.
THanks guys. My initial thought was to get a little more shock length, but I still can't decide if its the best way to go.
An interesting side effect of inboarding the shocks is that you get a lot more wheel travel than the shock length would normally allow....
In other words....A 12-inch travel shock mounted at a 45 degree angle gives a lot more than 12 inches of wheel travel. That might be interesting to you depending on what you're after.
However, the #1 drawback of angling shocks so severely is that the effectiveness of the shocks is just about cut in HALF....so buy a stiffer shock than what you think you really need. Or get some of those fancy adjustable ones and crank 'em up to full-stiff!!! :D
:usaflag:
Its a balancing act between road manners and trail ability. I usually drive 10 or more hours to hit trails. I don't want to lose the ability to drive 70mph on the highway.
i like this setup:D thats what i want to eventually.
that guys build up is on pirate, its pretty sweet
cbbr said:
I'm thinking that road manners are pretty far down on his priority list. That is a sweet setup though.
And with a tubed-out buggy chassis, he has all the freedom in the world to locate the shocks out close to the wheels where they actually belong... :(
well with the rest of the body on it, i dont see why it wouldnt handle decently on the street with limiting straps (in his case chains)
Why hasn't anyone mentioned this?
One of the main benefits you can get from a new shock crossmember is eliminating singls shear on both shock mounts. These vehicles weigh enough that single shear is a major factor for breakdown. A shock bolt supported on one side only is simply asking for trouble. And it is way to easy to remedy.
Huh?:confused: What is single shear? Am I daft? Forget that last question.
Why hasn't anyone suggested hooping it into the bed?
Single shear - shock supported from one side only by the thru-bolt
Double shear - shock supported by a thru-bolt that has metal tabs or bracketry supporting it from both sides of the eyelet.
Double shear is a lot stronger, and if there's a way to do it...it's the preferred method to mount things.
Got it, thanks!
