shock length spacing....1ton vs .5ton
K85 Octane
People Fatigued
San Bernardino CA
in the front
from the mount on the frame
to the mount on the axle.......
what is the ~difference in length between a d60 and d44/10bolt axle, if any difference at all
thanks :waytogo:
**Putting a D60 where my d44 was in my blazer. Put Furd shock towers on and contemplating moving them up again, unless the d60 shock distance is longer.
I need to check my two axles, unfortunately they are in separate locations. I thought the D60 lifted the truck a slight amount, being the spring pads are higher from the tubes. I thought maybe, that would also translate into the shock tabs being further away from the frame.
at most, like 5/8" away
just checked napa online and
1/2 ton ext length is 18.375"
1 ton is shorter at 18.250"
not much but like said bolt in swap.
Finally got a chance to measure the two axles. The D44's shock bracket sticks down farther than the D60.
From center of shock mount to top of spring perch:
D60: ~3"
D44: ~3.25"
all else being equal, this is where the length comes in.
