shock mount options
G-Force8
DFW, Texas
I will be running longer,inboarded shocks in the rear of the 'burb with a crossmember between the framerails
Up front,however, I am not sure. Any ideas on a bolt-on type mount that will work up front on a '91 burb?
I thought about maybe trying a pair of '99-up Ford super duty towers. I plan to use a pair on the front of my FSJ Cherokee and they look like they may work,but haven't been able to mock some up
If you do a search you will find plenty of people using the Super duty ford shock towers, they even buy them new, they are cheap enough.
I just installed mine. I had to be clear of the steering shaft and clutch z-bar on the driver side. Also had to clear the AC box on the pass. side. I'm running 12" travel shocks just about centered for travel. Not that my 6" springs will ever let me get full travel.
There are alot of guys here that know alot more than I do when it comes to stuff like this. If I can make it happen, just about anyone else can too.
Yea, $25 a pair at the local ford house
Looks good man. Looks like I have my answer
Thanks, did a lot of searching here on CK5. These guys have ALL the answers!
