k5 krawler 50
Well i am getting everything ready to do my 52" spring swap up front, and i am going to be using the ford shock towers with my 15" travel pro comp es 9000 shocks. I have a couple question about mounting them up though. I was wondering what should the shock tower length be(from the bottom to the eye for the bolt), since you have to cut some of the tower off i believe. Also i thought i saw a webpage on here on how to do it , but since i am doing the 52" springs, do you guys think its ok to mount them behind the little hump in the frame? I am just wondering on how much of the chrome shaft should be showing when sitting on flat ground, and the total length of the tower after its been modified. Any help is greatly appreciated. Thanks.
Cory
Cory
