Shock question for those with 52s on the front.
jake 03
3/4 ton status
Burlington,Co
How do guys have your shocks mounted when you have 52s on the front?
I have Fox 2.0x14 shocks and ford towers and its not looking good as far as it all fitting. I'm thinking I will need to build shock hoops and figure out how to make that clear my ac.
This was my setup. 14” Bilsteins with RuffStuff hoops.
I plan to copy @obijuank5 set up on the front using the extra quad shock bracket/position, his truck has a lot of flex so that seems to work good and it's dead simple.
You can make the ferd mounts work, I had them for a while before swapping frames.
Current hoops with 14" Fox 2.0's.
