I just finished swapping my 12 bolt for a 14 bolt and I noticed the shocks (ProComp) were fully extended. my rig has a 4" lift and might see another 2" at the most in the future. what shocks do you guys recommend? what length/compression should I be looking for? I do not have access to a forklift or RTI, so if anyone has already done the flex work I would appreciate the info for both front and rear. I plan on wheeling it, the previous owner did not. it has 4" lift blocks in the rear (will be getting shackle flip in a few months) and 4" lift springs up front. I have an ORD swaybar disco that I'll be installing along with longer brake lines. just need some help with shock info, thanks.
but I don't drive it much. I still got the stock bumpstops so I'll need to figure out what to do with those. I'm still working on the front axle 6 to 8 lug conversion & swapping in extended brake lines. I'd like to get all that done before I flex it out. hopefully later this week, but probably sometime next week. thanks again.
