Need to run power to the shop, yes I am making progress.
Wire I have is good for 150 amps. It is 2/0 2/0 #1. So my plan is to put a 125 amp breaker in my current panel. Then run it to a 100 amp panel in the shop.
So 2 questions. If I get a 125 amp load center and I upgrade my main panel, can I switch the subpanel main fuse to 150 amps at that time?
Should I just get a 125 amp subpanel. My thinking is if the shop has 100 amps then at worst it will pop the 100 amp breaker before the 125.
The reason for the 125 amp breaker in the main panel is it takes less space than the 150.
I had a 100 amps in my old garage. Never had an issue but my wire will be capable of 150 amps I wanna be able to upgrade if I ever need too
