Ha, I'm actually going to be robbing that 6.2 truck of it's wiring this afternoon
Did you notice they have two 5.7L diesels there too? Never seen one of those critters in person before yesterday...
If you have a good set of heads, I'd happily make the trip out your way to pick them up!
It sounds like your 80 is a lot like mine, mine is a GMC 3/4 ton 4x4 with 350 / SM465 / NP241 10 bolt front, 14 bolt rear. Lifted 4" up front, and 5.5" out back.
Funny thing is that my donor truck is also a 93 1 ton 6.5td / NV4500 rig! The 6.5 is toast, it has a nasty bottom end knock when you manage to get it started, and smokes like nothing I've seen before. Only runs on a few cylinders at first. However, once it warmed up, it actually ran pretty nice, all the smoke dissapeared, and the engine quieted right down. NV4500 shifts really nicely, despite having a big crack on the bellhousing by the slave cylinder...
I think I'm gonna trade the transmission off for a 95+ version though. I don't badly need that super low first gear, and an internal slave setup strikes me as a very attractive deal. The 95+ master cylinders are easily retrofitted into the older trucks, and the clutch line should bolt straight up... Solves all my problems with needing an advance adapters bellhousing, and some sort of slave cylinder retrofit. My NP241 should bolt straight up, but I'll need to find a longer front driveshaft, and get my rear one cut down.
