bot0611
Theres a cool spot near my house that id never seen before, it has 3 nice climbs one better than the other, so we decidid to try it out, me in my truck and my buddies ranger to test out his positraction.
I had no 4wd, no front driveshaft...
On the first climb i was short half way, the soil is very powdery and loose, the sencond time had a shortage of gas, the third i gunned it and got up.yieiiiii....
Next hill didnt even try it, youll need 4wd for sure.
The third one was the on that crapped all over my hopes...its a mix of the hills, bumps, rocks (huge by the way) and loose dirt...excelent for any off roader, i didnt even got through the first hill i started slipping, second try gunned it a bit no luck....the third is the best right?? WROOONNNGGGG.... got all 3/4 of the way started loosing traction and again the car died on me, so it was a mess backing up couldnt stop it with engine not running...
The main thing is this...one of two the pemp or the carb crapped out on me every time..... i have a mechanicall pump (carter) do i need to try out another brand, or go electric, ive been told holley suck if used daily, they tend to work when only demanded at moments, like drags or pulls..
What tou you guys think...
