badmix
pulled dash to replace speakers and cleaned up some old wires under dash and removed cruise control from engine bay, left electrical connection dangling and jus cut the vacuum line.
Anyways didnt mess with ac heater controls or wires. I did fix top of blend door behind glive box.
Anyways was running truck and running controls thru their cyclics to mske sure blend doors doin their thing. When i moved control to ac, i fully expected to hear compressor, it did nothing. Its 35* out right now, but being okd truck, figured it would kick on, now there is a chance im outa freon in system, last time i ran ac was long time ago, but its not even trying to come on, usually low freon will kick on and then off.
Also, i pulled black and green wire from compressor and didnt read any voltage, i checked fuses under dash all checked good.
Should i have power to compressor with ac in max position?
Yes, i know it’s winter but i would think it would work
Was reading about jumping compressor with paperclip to test compressor, how do i do that ?
