Should I get +11" brake lines?
MudFrog
Daleville, Va
Should I get +11\" brake lines?
When I finally swap in my front 3/4 ton axle I want to add some extended brake lines. Right now I have a 4" lift with sway bar disconnects. But I will probably add 1" add a leafs, and possibly one day go with a 6" lift. Should I get +11" brake lines for the 4" lift or should I go with a shorter line? Also should I get the same length for the rear?
89 K5 Silverado
<a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
Re: Should I get +11\" brake lines?
What I'm doing for mine is I have 4" lift with rear 1" zero rates and front ORD shackles and disco's...and my .02 cents are to add 2" longer then height of lift and atleast 2" for the disconnects so 8" longer and since you're going to a 6" later on might as well get 10's or like you said the 11"s. Where you getting your lines from? I have a local shop I have been to twice this week at different times and both times they were closed
But they offer up to a 30" line. I measured for mine and I think it is like a 20" line.
<font color=red>Life is like a mud hole:</font color=red><font color=blue>
When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
55 Willy's
The Napa lines I have up front are 10" longer than stock.Iv got 6" lift up front+sway bar disconnects and there perfect.I cant rember how long my rear one is.
A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
Yeah, for the rear, just get the SS hoses for a 4" lift. The hose will hang down in the middle of the rear axle, so you don't need it long since it usually doesn't flex out all that much.
The front, I would get SS hoses for a 10 or 12" lift. I think they are like 28" long. My hoses are 34" long (front), but I think it's more than I really need, but oh well.
Pic of my truck Before N' After
<a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
I was looking at 4 wheel parts and they have the Superlift SS lines that are extended 11". They seem kind of high, $97 so I'll look around but Superlift is what I will probably go with.
89 K5 Silverado
I just called the local 4x4 shop and he wants $99 for a 6" front line and $59 for a 6" rear line. Way too much.. He also said the 6" would accomadate up to 10" of lift. I think he is not aware that vehicles flex. While 10" of lift might work with the 6" it probably wouldn't flex any. He only builds trailer queens anyway so I'm sure he has no clue.
89 K5 Silverado
It takes a little more work than buying them completely put together but I picked up some lines from speedway motor pretty cheap. I just need to either locate the fittings locally or get them through speedway but I haven't gotten that far yet
Their site is <a target="_blank" href=http://www.speedwaymotors.com>www.speedwaymotors.com</a>
-Aaron
___ __ _ _ ____ __
AGM73k5 -- [email protected]
Emmetology101 has the +11 superlift lines on his truck and likes them a lot. Said he tore one off and they warranteed it. I bought them for mine, but haven't installed them yet
Sherman, Tx
<font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
That seems awful high for 3 lines.
I have bought some from Skyjacker for around $100 for all 3. And those were to fit a 6" lift.
I'm not picking my nose...I'm just pointing at my brain!!
<a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
Be careful with superlift lines. Make sure all the ends are steel not brass. I had a line fail on me because it was a brass fitting going into a brass end. They cant take the pressure of the hard breaking and they will snap. Mine brake line failure unfortunatly destroyed my Jimmy and almost killed me.(Rolled 6 times down a 75 foot hill)
86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
Lawsuit! Lawsuit! Lawsuit!
89 K5 Silverado
