I have a 89 GMC Jimmy, 350 TBI. Motor was replaced with a NEW stock crate motor from GM and professionally installed a while ago. I’ve always had a little bit of a miss at idle that still persists even with the new motor. All ignition components were replaced when new motor was installed, AC Delco all parts, cap, rotor, plugs, wires, IAC, ignition coil, ICM, fuel filter, rebuilt TBI etc. The only thing that is carried over from the old motor is the distributor, and probably the harmonic balancer. The pick up coil looks really rusty and green corrosion under the cap. I figure I might as well just replace the whole distributor Incase of worn gear etc. and that is the only ignition component that hasn’t been replaced. Do you think that the distributor could be the cause of the slight miss at idle, especially when warm and in drive while stopped? Runs excellent at all other rpms, under load etc.
Gotta go get a new one tomorrow. Always something
Will update after I get it timed and test drive it.
