merace19
As the title says. I looked at a 6.0 in a truck. and after driving it for about 30 minutes in 70 degree temps the coolant system never got pressurized. I could take the cap right off the cooling reservoir.
On the last one I ran, again not a 6.0 but the same pressurized bottle system, there was pressure after reaching normal operating temps. It wasn't a lot of pressure like you would get when removing a radiator cap. There would be a small hiss of pressure release, but the plastic bottle cannot take a lot of pressure.thanks for responding. If you have a newer 6.0 engine then you would know that the radiator has no cap, its on the reservior. So it must get pressureized correct?
That bottle is solid looking. Hell most radiators are plastic now.On the last one I ran, again not a 6.0 but the same pressurized bottle system, there was pressure after reaching normal operating temps. It wasn't a lot of pressure like you would get when removing a radiator cap. There would be a small hiss of pressure release, but the plastic bottle cannot take a lot of pressure.
