Side Windows
wags86
Registered Member
new jersey
I am looking at replacing my fixed side windows with the ones that slide open. Does anyone know what is the best way to remove them with out either breaking the windows :D or messing up all the seals? Has anyone ever done this type of thing that can help me out and let me know what to watch out for and what to expect?:bow: thanks
You can find tops for cheap, I have 2 and can't get rid of them for anything. if you have a blazer then you usually don't need a top, hah man they take up alot of space too! best bet would be to buy one, or trade yours for one, as stated, unless you like changing windows, if so then go for it hah. I always have bad luck with glass, last 2 windshields I tried to remove I broke. good luck.
Search is your friend don't be afraid of it. :haha:
Metrodps said:
The seals are two part the rubber and a rubber insert locking rubber. I believe the main seal is like $99.00
Here is how I did my window change it was easy to do. You will need two flat head screw drivers and spray bottle of soapy water. A very small flat head to reinstall lock rubber. *if you have a window install tool works best about $5.00 for it. Looks like a pick with a pigs tail end.
1.) looking at window from outside you will see a little metal clip in the middle of rubber at the bottom. Take a small screw driver and pop that out.
2.) You will now see a small gap between the inner rubber strip. Take one end of it and pull it out in a lifting manor (away from truck).
3.) Now you will need two flat head screw drivers. Start a few inches from the lower rear corner and insert one screw driver in under the lip of the metal frame. Next spray some soapy liquid on rubber and insert other screw driver and work it around to lift the frame/glass out of rubber. *works best going to top.
4.) Once you get the rear upper corner out it is a breeze. Keep going till you have most of the top out of rubber. At this point you can pull the frame/glass out.
5.) I took the seals out and cleaned them in warm water to get crude and old black goop off. I used a butter knife to get it clean (DO NOT LET YOUR WIFE SEE YOU DO THIS). :mad: :bow:
6.) After they were dry I put a thin bead of black RTV on the fiberglass lip and placed rubber onto it.
7.) I then placed the lip of the frame/glass in to the front corner of rubber and started to wards the rear. Using the screw driver to pop the outer lip out at the rear and worked on up and over to toward the front. *you will need the soapy liquid from time to time.
8.) Once you have it in you will take the thin rubber piece that you pulled in step 2. Start in the middle bottom and insert it into the gap in the rubber *I used a small flat head to push the upper edge down into channel. The best way to describe this motion is kind of like a wrist flick or reverse knock.
9.) Now if you did every thing right you should have a little extra locking rubber when you get to bottom *(stretches when you pull it). Cut this as close to the other end as you can (about 1/4 inch).
10.) Now you will replace the metal clip pull both ends out just so you can slide them into the clip. Now press it into the grove.
In step 3 you just do the same but to the glass on a fixed one. Mine had fixed glass and I changed it to the sliders. Pm if you need more help.
And now you know the rest of the story! Page three... :D
Thanks for the information, i tried to search for it but did not have much luck, I guess I should have had by 11 Yr. old son do it for me. i am more of a type writter/ white out type of guy than computers, ha ha, thanks again, when i get going if I run into issues i will PM you, Bob
cbbr said:
I replaced my side window in 15 mins. Once you realize that its just a gasket holding it in, its easy.
Yea a glass place wanted $200.00 to install mine. I used to work at the Jeep plant here in 1979 & 1980 one of my jobs was to install the passenger side rear windows into the fiberglass top after I put it on the conveyor to go to the jeeps.
So after studying the gasket I said Heck it was not that different and what the hey. So away I went and like CBR said it didn't take long. If thieves knew how easy it was they never would break a window again!!! :doah:
