Simple question...
speedyvision917
CT
What years and what model trucks did GM put the 12 bolt in? Thats all, thankyou.
They were in many trucks from the 60's to 82 .
The ones in Blazers from 69-72 have the one ton perch spacing . And the ones in 73-82 Blazers have the 3/4 ton perch spacing .
Some gearsets and yokes fit from cars , but basically the 12 bolt truck is entirely different .
best guesses...
I've seen them in 67-80 GM trucks,but they might have used them in older years too..I had several first generation (67-72) trucks with 12 bolt rear axles,my 79 C10 has one...someone else probably has the exact years listed in a GM book I bet... :crazy:
Edit!--they used the 12 bolt in 1/2 ton trucks only,as far as I know..(C-10,K10,K5,)... :crazy:
I hope your right deisel, im looking for exact years, i havent been able to find anything online though. Pauly how do you like running the 12 bolt? and what size tires are you running with it?
Some were 3/4 ton in the 60's and had six lugs on 2wd's , using the 12 bolt truck .
I love my 12 bolt , I run it locked with 10 bolt ( bigger , mine was a 73 2wd axle ) drum brakes . And the other one is locked with a 1350 yoke . I have 2 trucks .
I only run 33's for now . 35's on trail truck , but it hasn't driven yet .
I know a guy who broke some stock shafts doing crazy trails , after 20 something years of being in the axles . He runs Superiors now , and I don't think hes broken one :D
'64-82 is official years of the truck 12 bolts, trucks, blazers, burbs, 10 vans
most all under 5 and 10 series trucks however i know some of the old 20 series vans were 12 bolt til starting in 77 when the trucks blazers burbs also started going 10 bolt
good luck
