How bad is it bowing? Just read that single wall tops have "strips" (one guy reports they are wood) running through the top to keep it from sagging (none-the-less it still does happen, just less so than the double). Maybe something was set on yours for a time and caused the wood to crack and the sag to be there? Mine has a square hole cut in it, and a cheap repair. So I can't speak to how bad it sags naturally, but I see waves in it from a bad fiberglass repair.
Here is a thread on 67 about the tops that may interest you:
http://67-72chevytrucks.com/vboard/showthread.php?t=518847
Post 4 has schematics and Post 12 is a repaired single wall that he just decided to coat as best as possible and live with a little sag.
Some of the guys on here might have more ideas. Also a couple guys (not first gen owners) work on boats and are familiar with fiberglass repair.
