Single Rear Wheel, one tons
grendel
Boston, MA
Chevy Dana 60 front with good tie rod, Corp 14B rear with CUCV drum brakes
4.10 gears, open front and rear.
They've been sandblasted and painted. Rotors need a turn, but should be fine for years to come.
1100.00 plus the ride.
Located in Derry NH
How are CUCV drum brakes different than civilian brakes?
Forgot to add, these have an anti-wrap bar mount on the rear, from RuffStuff Specialties.
willing to seperate? i have a 14 bolt, just need a dana 60
The value really is in the 60, so I'd separate but all you're really saving is shipping costs. I went through this axle, using all new parts from Highonda on Pirate.
It's the axles from the Pirate JunkYard Dog... a build up we did. We're swapping in a set of CUCV axles.
http://www.pirate4x4.com/articles/productreviews/extremeaxles/
The rig hasn't run since it was built... so we're working on that now.
To confirm, we're pulling the axleshafts, hubs, brakes and high steer. We'll swap in the low mileage (CUCV with 8K) brakes, hubs and axleshafts. If it needs ujoints, it will get them. Same for bearings and the like.
No locker in it, although I do have a 4.10 Detroit that can go with, if interested for additional $.
What would it take to ship them to Austin, TX? (78748)
I have a couple of friends that are over the road truckers. He may get to Austin, in which case it would be cheap. Not sure on commercial shipping, as I have no accounts. I can drop them in Manchester, NH or Boston, MA at any terminal you wish.
