Size lift I have? I apologize in advance !
sleepymarks
Registered Member
Charleston, SC
Sorry NEWB here. Can anyone take a shot at what size lift I have from the pic in my avatar? I don't have access to anymore pics, SORRY!!!
If you measure from the top of the axle to the bottom of the frame I will compare to my blazer and let you know. There is also a thread with this info somewhere, sorry I'm not sure how to post links from my phone.
with 31's, I'm thinking stock. Are your front springs flat or inverted, or do they have an arch to them? If no arch they are stock height springs.
This might help...it's roughly what to look for, assuming you have stock front shackles (I think they were about 4.5" long) and nothing on the frame has been changed, all of which is unlikely anyway.
Basically, if you have a positive arc spring, lay a straightedge or something across the spring eyes and measure to the center pin on top of the main leaf. If that measurement is 2", you have a lift spring that is 2" (your measurement) + 2" (the arc of the stock negative arc spring) = 4" lift spring.
Or in other words, a perfectly flat spring with no curve to it would be about a 2" lift spring.
My Dad grew up in Charleston, most of his family still lives there.
Wow that's perfect. Just what I was looking for! I noticed some steel hollow square tube pieces above the frame which makes me think he (previous owner) put some kind of lift on it.
I just moved to charleston, sc. I'm loving it! But I'm coming from Newport, or so anywhere makes that look terrible. Haha
