sizing rings
solowookie
Wyoming
ok guys...
here's the quesiton - when I size the rings do I size the rings in the cyl. they are going on, or can I size all the rings in one cyl.?
when I get done is there anything I need to be careful of so I don't break them when putting them on the piston?
Are the rings you are using file-fit rings?
Theoretically, all the bores should be the same diameter so it would be okay to use one cylinder. You've got it apart though, so you may as well use each individual cylinder.
Remember to file in towards the center of the ring, and make certain that the rings are square in the bore while you are measuring the gap.
A set of ring expanding pliers is virtually a must when putting the rings on the pistons.
A light chamfer of the bores will guard against ring damage when putting the pistons in. Make sure you cover those rod bolts too so you don't damage the threads or the crank throws.
when I go to file the rings can I put them in a vice? I'm kind of worried about scaring them? how do you usually hold the rings?
You should put the file in the vise & push the ring across the file to prevent ring damage. Due to the price of good rings, it is advisable to buy a ring filer to prevent damage (probable with the vise method). A ring set for 1 cylinder is usually special order & approx $30 & up so a $75 ring filer is not that unreasonable & you will still have it when you are finished. The file/vise method is crude at best & is hard to keep the end gap parallel.
Lonnie
appreciate the info... actually I sized these yesterday, and I didn't have to resize any so I got lucky, but I was still curious in case I needed to file any.
