Skid Plate
nocok5
Northern Colorado
Anybody have any pictures of how the factory skid plate bolts on to your Blazer. I have a 1990 Jimmy and the previous owner removed the skid plate when changing the fuel pump. I would like to put it back on, but am not seeing how it bolts up. Thanks for any help.
Now I'm thinking that you're probably talking about the gas tank skid since you're talking about the fuel pump... And I don't have any photos of that.
IIRC at the rear the mounting tabs fit over the gas tank mounting strap studs (so nut holds the straps on, then plate mounts over those nuts) and on the front I just can't recall...same situation, or bolts?
I just reinstalled mine after having it off a while. There's really not much to it. Put it over the tank and you'll see where the 6 holes are. Bolts come through the top into the captive nuts in the skid.
I need sliders next...
