SKY Tall Steering arm
Hossbaby50
3/4 ton status
Peoria, AZ
I just got my D44 tall steering arm in from Sky today. This thing is HUGE. :D This thing is majorly beefy. I couldn't believe how big this thing was when I took it out of the box. It is a very nice piece of machined metal also. SKY makes some good stuff. I am impressed once again by them. Customer service was excellent and my order shipped the next day. :thumb:
Thanks SKY
Harley
P.S. If you are installing this arm and want to use bolts the length you need is 2.75".
Sweet I need one of those so I can get rid of my spacer. Yep Sky rocks :D Hey what kinda studs were you looking for?
I was looking for ARP studs but I talked to Sky about my setup and he said I should probably just continue to use the F911 (Grade 9) bolts that I am using now. So I got some new shorter F911 bolts and installed the new arm earlier tonight.
I had to get this new tall version steering arm. The spacer is a very bad idea. I learned the hard way. I snapped 2 steering studs the 2nd run out on it and I stretched and bent Grade 9 bolts after about 10 months of hard use.
Harley
ahh ok I was just wonderin I have 3 3" studs that I got with my arm a while back.
