Skyjacker dana 60 and 14 bolt question
TOMER
Israel
Hello,I finally decided to lift my truck with skyjacker leaf springs,My question for you guys how run the skyjacker 4" lift with 14 bolt and dand 60 is:
what is the hight from your fender to the ground (rear and front)??? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
thanks
I've got 4" Skyjacker front and rear springs on my K30 with 35" tires, but the before your question can be answered, what size tires are you running? /forums/images/graemlins/dunno.gif
You can also measure from the center of the hub to the top of the fender for a true lift comparison. Tire size / rim width / air pressure, don't matter if you measure it that way.
Yes,you right,your way is much reasnable then mine!!!
According to that i correct my question to:
I nead someone with 14 bolt,dana 60,4" skyjacker lift(if ther is body lift please mention it),to take measurement from the top of the fender to the center of the hub(front and rear please).
Thanks
/forums/images/graemlins/confused.gif ! /forums/images/graemlins/confused.gif ! /forums/images/graemlins/confused.gif !!!
One last time...any one with 2.5" , 4" , 6" , 8" skyjaker lift (I'll do the math).
thanks
[ QUOTE ]
Hello,I finally decided to lift my truck with skyjacker leaf springs,My question for you gays how run the skyjacker 4" lift with 14 bolt and dand 60 is:
thanks
[/ QUOTE ]
Maybe noone wants to help cause you're calling us gay??
j/k
I have an old 4" and I probably have 25 -30" from the ground to the fender.
Nick
you're running 35's and only have 25-30" from ground to fender? /forums/images/graemlins/confused.gif
i think so. im not real sure but just a bit of the tire goint into the fender. Im not real sure cause I just broke my tape measure. Ill go take another look.
i just went and measured it and I was close. I have 24" from the ground to the bottom of the fender running 35's.
Nick
Give Wes a chance to put some pants on and get off his lazy arse and measure for ya /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif...he has that same combo on his '85 K30 /forums/images/graemlins/peace.gif
I am very sorry, what I intend to write was " guys " .
I did not want to hurt any one. My mistake that I didn't write that my English is very bad,forgive me .
And again I'm very sorry!!!
/forums/images/graemlins/rotfl.gif /forums/images/graemlins/laugh.gif Relax and loosen up man! unick was just jokin around /forums/images/graemlins/histerical.gif
if you have spelled a word wrong, no matter what it is, someone WILL point it out...its the nature of the forums....its all in fun /forums/images/graemlins/peace.gif
