Does anyone know if the slave cylinder from an SM465 will work on the factory NV4500 bell housing. My drive shaft is on the driver side, so I can use the factory bell. Thanks all.
It should be easy to tell at a parts store. The nv4500 stock cylinders have two mounting studs that bolt onto the bellhousing. Check that against the mounting locations for the 465 slave. I'm guessing they are different, but you might be able to modify something to make it work.
