Sleeve
I've never used your set up myself but I'm fairly familiar with the parts. You should be using a th350 version 203 which is female so you shouldn't need a coupler. I would think it should be -
700r4/spacer/th350 adapter/203/doubler adapter/205.
Sleeves are used on early 465/205 and all th350/205 combos. Afaik, none of the GM 203 combos used a sleeve, they're all female input.
