Sleeved Tie Rods
ryan22re
Irmo, SC
What's the consensus on sleeved tie rods? Good idea or not? I ordered a 1.25 x .250 wall tie rod. Dunno if that is big enough for 42's and hydro assist. Was thinking of sleeving with 2 x .375 which I think would be more than enough. Was thinking using a tubing notcher, notch the ends of the sleeve and weld in a C shaped pattern on both sides at each end. Or should I just sell my tie rod and but a 1.5 x .375 wall rod? Oh and it will be a low steer tie rod if that makes a difference. Was also thinking rosette/plug welds along the tie rod, but I dunno, I'm not a fabricator by any means.
Your thinking of sliding the two together. I doubt it will fit. Usually the DOM tubings won't fit together like that. You'll either have to turn down the smaller a few thou or bore the larger.
I have access to a lathe... How bad are the I.D.'s on DOM? Are they that bad? If I did turn it down, would it work ok? Or should I just buy the big boy?
Basically you'll just have to do a clean up pass. Should be good and round. .005"-.008" should probably do it. I don't see any reason why it won't work. Pretty heavy. Sometimes with all the bigger beefier tie rods you see, I start to wonder at what point the weight of the tie rod compounded by inertia will be too great. Maybe it will never be a problem.
mine is sleeved (rockstomper)... and yes, its quite heavy. I did put a minor bend in mine when wheelin'... so its not like sleeved stuff is unbendable. The bend hasn't really effected performance or anything.. I guess a thinner one might have been ****ed. ;) At the moment my tierod has decided to hide above/behind the front diff... I think its safe. :thumb:
j
j
Same tie rod and that is where mine is going. Funny mine has a slight bend in it too.....
I have a sleeved tie rod I bought from Sky Manufacturing. It is a 1.75" OD, with 1" shank tie rod ends. Sky stop making these (I think) because Left Hand thread 1" diameter shank tie rods where getting very hard to find; plus non-sleeved tie rods with a 1.50" OD, and 3/4" diameter shank tie rod ends are plenty strong enough for any application, so why bother with anything larger.
Sleeved here 1 1/2 ovr 1 1/4 both pretty thick cro-mo. hit a rock at about 5 mph and it laughed at it. 3/4 heims at both ends
