liljoe8865
Registered Member
Should my rear drive shaft be a slip-shaft the reason why i ask someone mention that was odd! should it be solid in the rear? the truck has a 6" lift real bouncy the u-joint busted from the rear drive shaft but the upper side of the u-joint does it make a difference whether or not the front drive shaft is on or off? does having both shafts stiffen up the movement/bounce of case?
