I am getting a little slop in the steering. Nothing horrible, but it turns a little before the wheels start. What should I be looking for? Steering box or one of the bushings?
rag joint is probaly the culprit but it also helps to have a friend slowly turn the wheels lock to lock while your under the front looking for tie rods and drag links that have play in em
well, not sure if its the same here, but i noticed after replacing my front rotors and setting proper load on the bearings durring reassembly, my steering was vastly improved. Its a quick, easy, and cheap thing to do before you start spending any money. all it takes is the big socket tool for the hub lock nuts. and an afternoons worth of work.
