I think I dinged my aluminum rim on a rock and now even after getting new tires put on I still have a slow leak. Whats the best solution?
A can of that nasty tire crap?
i would find the offending area with soapy water, mark the location with a sharpie, dismount and see what the prob is.. you may be able to just smooth/sand/file/smash/nuke it to where it'll hold a bead...
) so we'd grind it off, then apply the bead sealer. It always took care of it as long as the rim wasn't cracked or had too big of a dent in it.goop you put on the bead when installing.. like a gasket sealant..
