First of all I wanted to say that I found a post that sounded like it might be the same problem I'm having, but it wouldn't let me post on that thread so I've started this one as it didn't seem to be resolved. If anybody knows anything, thanks in advance. The truck has been in service since 1990 and has over 500k miles on it. A lot of these miles I put on it myself, the rest were the old man. I am very familiar with the idiosyncrasies of the sm465 and it's a rare day when I make the slightest grind going into L or R. I'm making two points: that this is a high milage transmission (although in my opinion the sm465 is capable of many more miles than this if driven properly) and that this is not operator error. Sometimes she shifts like she just rolled out of the factory, sometimes like there's no clutch at all.
It'll go something like this: I'm parked, and cold start it. With the clutch fully depressed and proper resistance from the pedal it will just grind when I try to engage anything. I have tried to put it in 3rd and 4th while at a standstill, just to see if they would engage. They just grind too. Then I FORCE her into reverse, and she shifts perfectly for a while until she arbitrarily doesn't again. Always seems to disengage properly but sometimes just won't go into 4th after coming out of 3rd when the rpm is near matched anyway. And then sometimes when it happens the clutch pedal goes soft. It'll shift poorly for a moment, and then like it's brand new again.
I even broke down and took the damn thing to a mechanic, which never happens. It shifted perfectly for the whole test drive.
The master and slave cylinders are both less than a year old. The clutch is about 18 months old. I bled the line yesterday, thinking there might be an air pocket. No such luck, or if it is its still in there somewhere. Any insight would be appreciated.
George
1990 C3500 454 sm465
George
..all that work and 200+ bucks for nothing..
...other two "dragged" and failed to release fully,and chattered badly --they all failed in a month or two,so I decided to drop down from a 12" to a 11" diaphram type clutch--first time I pushed the clutch pedal down I think I dented the floor,it was SO easy,I thought something was wrong!..
