Moody
O.K....I just spent all day putting in my 465 in my 70 blazer that has a 406. It was a PIA to get everything lined up and the splines on the shaft lined up. I installed the tranny without the top cover as I am having the shifter forks replaced and when I tightend the transmission down to the bellhousing I could not get the engine to turn over (manually) with the transmission in neutral. When I loosen the bolts from the tranny to the bellhousing I can manually turn the engine over and see the gears in the transmission turn. I know the splines are lined up but how easy should the engine turn. The engine is brand new, never been started.
