You know I have heard that that problem is caused by a c-clip that flexes and allows it to pop out of gear. I was going to have mine swapped out with a pressed on spacer but when I pulled my gear box apart I found it was already put together like that. I guess sometime around the early 80's Muncie also saw this as a problem and fixed it. My father was the first owner of this truck so I know he never modified it, and I am the first one to ever get inside the transmission.
Maybe you could find a "newer" sm465 and swap mainshafts. Wouldn't even be that hard!
