SM465/205 and a 10 spline 203
mnstrburbon
Buena Park Ca
I have a complete sm465/205 with chrome trans shifter, and the hyd bell-housing, components and pedals complete swap, it is mated to a to spline 205 i have replaced the coupler and completely cleaned and painted both and resealed it maybe 2,000 miles since done. The 205 has JD fab stainless twin stick installed with aluminum knobs i also have the boot. The rear out put is 1350 yoke the front is flange for CV drive shaft. The front out put is the 30 spline not the early weaker 10 spline. It also comes with both cross members and factory skid plate, extra cross member, a good Luke clutch, front drive line, and a BBC flywheel a complete swap.
$900 OBO WILL NOT SEPARATE AT THIS TIME.
I pulled this set up complete from my suburban build as i am know building a blazer and am going 4l80e only reason for selling.
The 203 ten spine input is a complete range box and adapter only i disassembled the t case to build a double it is also all cleaned up and painted ready for a doubler you need only to by the doubler plates.
$350 OBO
PACKAGE DEAL $1100 obo
Sm465 203 range box
adapter
