stevos67k20
hey guys i just gernaded my sm465 and its really bugging me, heres why:
i was accelerating in third (or second on the shift knob) gear very hard and it banged real hard and my engine spun like crazy
. its a low rpm 454 so that wasn't so hot.
so i shifted in to 4th (or third on the knob) and kept driving. i parked. it was fine. and i drove home a few hours later. it was fine all the way home though all gears. note: i did not use the tranny to slow down, just the brakes.
right in front of my house i was down shifting from 4th (3rd on knob) to 3rd (2nd...) gear to slow down. i drive my truck alot and am very familiar with it and i knew it was fully in gear, anyways it rattled/grinded like crazy, i couldn't let the clutch out fully.
so i go "crap" and switch to 2nd (1st on knob) and it rattled/grinded like crazy also. ?????? how could this be? ive never had a problem with 2nd gear. its like 3rd gear took a crap and took 2nd gear with it, is this possible? i didnt drive more that 6 miles after the 3rd gear showdown.
a few hours after i parked it i went out to see if it fixed itself
while it was parked. i put it in 1st gear, it pulled forward, 2nd gear:rattled/grinded, 3rd gear:rattled grinded, 4th gear: pulled forward.
today i opened the top cover of an sm465 and ive been doing some research on it, enough to know that the 3-4 and the 1-2 gears have two different shift forks. any ideas on what could of happened? no i havent looked at it yet. if 3rd gear got screwed and 2nd gear did too, then could it be a deeper problem than worn shift forks, weak snap rings, or bad synchros??
i have a random question about synchros, in the sm465 i pulled out, it had square syncros but had beveled ends on the shift coupler..?(slidy thing) side. is this the "diamond type" synchro? it looks like they were cut that way, does this mean the trans mission was rebuilt?
i know this thread is long but transmission problems require a good description and information that might help. thanks chevy bros
. its a low rpm 454 so that wasn't so hot.so i shifted in to 4th (or third on the knob) and kept driving. i parked. it was fine. and i drove home a few hours later. it was fine all the way home though all gears. note: i did not use the tranny to slow down, just the brakes.
while it was parked. i put it in 1st gear, it pulled forward, 2nd gear:rattled/grinded, 3rd gear:rattled grinded, 4th gear: pulled forward. today i opened the top cover of an sm465 and ive been doing some research on it, enough to know that the 3-4 and the 1-2 gears have two different shift forks. any ideas on what could of happened? no i havent looked at it yet. if 3rd gear got screwed and 2nd gear did too, then could it be a deeper problem than worn shift forks, weak snap rings, or bad synchros??
