so i put in my sm465 and i went with the hydro setup. im using a mech bell housing but i purchased this conversion from novak ( [FONT=Verdana, Arial, Helvetica, sans-serif]#HCR3[/FONT] ) and im using the factory MC. it is all bleed right, and i found a small problem with the firewall flexing, so i put a small support. but it still barely dis disengage. the rod from the Slave to the fork is out all the way too.
my thought is that maybe the master doesn't work well with the slave. but it says it works with [FONT=Verdana, Arial, Helvetica, sans-serif]3/4" to 7/8" MC. [/FONT]
anything will help. thanks!
by the way this was a swapp from a 700R4 to the sm465.
