Sm465 cross member bushing.
Jake_C_
Ohio
I’m looking for the bushings that mount between the transmission crossmember and the transmission. $60 dollars seems like way too much for something like this. I don’t care if they’re rubber or poly. If anyone knows of a set that fits that’s more affordable I’d much appreciate it.
Look at Rock auto. They have individual bushings. looks like you can get a set for as low as $10 assuming you have your old hardware. hope they last.
Thanks I’ll look into it. I have the bolts but the metal pieces are toast that’s my main issue. Thanks again
There is a metal sleeve that runs through those, then the plate
The factory ones are pretty good for stock uses. May be worth checking all of your engine and trans mounts and replacing all at once if you budget allows
Will look into it. Thanks.
Just ordered the parts on rock auto. I realized the metal isn’t too far gone to reuse most of it and the parts I can’t reuse I can easily fab up. Thanks guys.
