ok so my 1978 sm465 is nice and OLD... I replaced the NP205 gear oil few months ago and was easy...well I had a few brews and made a huge mess but that is a different story...
Pull drain plug... drain.... replace drain plug... remove fill plug and fill...
so now I have noticed what seems to be my trans making a noise in 4th or 3rd (however you want to look at it... L - 1 - 2 - 3 )
so I know I have a leaky mess (rear main and somewhere between trans and xfer.. so chocked it up to maybe low fluid.
First my googling got me this...
80/90 gear oil
3.5-4qts
Drained my trans last night and 7 quarts came out!!!!!! was a bit frothy too so most likely water? like said truck is 38 years old and I have owned it since 1988 and never changed the fluid.
so I put 4 quarts in it and wow it is actually harder to shift. Doesnt go into gear as nice meaning you can "feel the gears" when shifting.
so my question...
is 4qts enough?
lets start there...
80/90 gear oil
3.5-4qts
so my question...
is 4qts enough?
lets start there...
