cegusman
3/4 ton status
I am running a 465/doubler setup. Ran this trans before with just the 205 and no issues. The issue I am having is when in 1 and second there is a slight gear clatter like something is binding\grinding. Almost sounds like the top gear set has some front to back moment, very slight and it is catching something. I think I have an idea what is causing it. but wanted to get a second opinion before I pulled it.
With the 465 to adapter you have to run the factory gasket, or else the bearing will bind. Well when I put it together I used right stuff rtv on both sides of the gasket. Could this cause enough of an extra gap to possibly cause the top gear set to shift 1/16" or so and cause the gears to make contact were they shouldn't?
