Sold SM465 hydraulic clutch bellhousing, master and slave cylinders
It’s the standard GM bell to trans pattern ( pre NV4500 ) with a 5-1/8” index bore dimension if this helps.
Seems like I’ve read that when it’s used on a 4500 the trans typically ends up tilted a few degrees to the passenger side to make the most bolts work.
If the indexing hub is not the same I wouldn't attempt it because I don't want it to be off center or tilted.
I will let you know
