SM465 Hydrolic Bellhousing
DuallyK5
New Jersey
Does anyone know where I could possibly find a SM465 Hydrolic Bellhousing for a 1988 K-5 Blazer? I have the Pedal, Master and Slave Cylinder alone with the resivior. I also have the SM465 and the NP205 with the crossmember. Also if anyone has the SM465 Hydrolic Bellhousing even on there truck could anone possible get me the casting number? Also what else will be in the bellhousing besides flywheel, clutch, and pressure plate.?
GM part number is 15530202, if you plug that into gmpartsdirect.com it comes back as $218.xx before S&H. A fair chunk of change, but for what I've seen used ones go for, that probably isn't super unreasonable for a brand new part.
That number is *probably* cast into the bellhousing somewhere. Different than a casting number, but both, either or none of the casting/part numbers may be on them. Just depends.
You can't mistake the hydraulic bellhousing though, it has an "ear" on the drivers side for the clutch slave cylinder.
do a search for it on
car-part.com
I buy alot of stuff from there....
online junkyards are so way cool....
Thanks
Thanks for the information. That helped me out alot. I didnt think you could still get teh bellhousing but I was wrong.
i believe it is advanced adapters that sells a kit to use a regular bellhousing with the hydro clutch. that could always be an option
