I hear all kinds of talk about how much easier the pedal effort is with hydro setups, someone prove it.
Hydraulics are simply a way to use fluid as a mechanical advantage, just like levers.
Its not like the hydro-clutch pedals have twice as much travel, AFAIK the mechanical and hydro clutch use the same lever arm distance.
I've driven mechanical and hydro clutch K5's and I don't feel there is any difference in pedal feel. IMO, the difference is mostly in people's heads.
I'm well aware of the advantages/disadvantages of each setup
So, assuming you have frame/body flex issues under control (which I do and did when mine was full bodied) convince me why a hydro clutch is the way to go.
I've replaced many a clutch master cylinder and slave cylinder in my day, why does everyone think the hydro stuff is the hot setup?
