87 Blue Beast
i get this clanking kinda noise when im driving around in low. when i push the clutch in, i get the clanking noise, almost sounds like there is too much gear lash and the gears are boucing off each other. also, when its shut off and im gear, i can turn the driveshaft and feel play. is this a common problem with these trannies? or would it be more common to be a problem in the 205 case?
