mudhog
THEGAME
im selling my sm465 np205 combo kevlar clutch flywheel clutch linkage and clutch and brake peddle incase you want to swap an auto to manual. tranny was rebuilt less then 10,000 miles ago and clutch was put in at the same time. the clutch is a full kevlar clutch asking $400
These industry-leading Zoom High Performance clutch kits feature a disc with a dual-sided KEVLAR® friction surface. They're designed to hold up over time against high rpm, huge loads, and high heat. They are recommended for street/strip applications, towing or snow plowing, and off-roading. These kits include a disc, pressure plate, and throwout bearing where applicable.
