Sold SM465/NP205/NWBlack Box + Hydroboost
noahrob
Author
Santa Barbara
Hi,
Are you building a beast and need a drivetrain? My project went a different direction so here is what I have for you
Hydro Bell Housing with slave cylinder
Pedals for under the dash (with a clutch pedal if you are converting)
Hydroboost system complete with hoses and power steering pump
SM465 Round bolt pattern adapter
Np205 32 spline
NW Black Box Brand New in Box with shifter kit and 32 spline input/output
Im in Santa Barbara, CA
$3000 for everything
@tarussell looky (I know, I know but I had to tell you about it)
That's just not right..... If you buy all the parts to put the "BIG" roller wiggle-stick in your current BBC than I will step up and buy another reduction box !
Ball's in your court....
BTW, thanks for the heads up !
Im very interested, can you post more pictures of everything and give some more details as well as condition of everything?
Sorry, I sold the NP205 and Black Box. but Ive got a killer setup if you have a k series you want to convert over to manual or if you have a 1 ton needing parts.! You get
Sm465 with shifter and Hydraulic bell housing with slave cylinder (complete)
Hydro boost brake master cylinder and all lines (complete)
Hydro boost power steering pump and all lines (complete)
Triple pedal setup (brake clutch accelerator)
I had this for a rock crawler project I was doing but the project's gone. The bell housing alone costs over $400 on ebay. I need this stuff gone, so make an offer.
No worries, I saw your other post, ill go reply there.
