SM465 project
steelsoldiers
Charleston, West Virginia
I have that SM465 that I got with my parts truck. I popped the top cover off and it looks pretty good inside. It looks like there was some moisture in it though 'cause there is a little surface rust on a few spots. Can I just clean it up or should I plan on doing a bearing, seal, and sychro kit? What's the best way to tell if it needs overhauled? The Haynes manual shows that you need a bunch of special tools to overhaul it so I am hoping I can just do a little light maintenance. Thanks.
Chris
the hardest part is getting the counter shaft bearing out
rent a snap on puller cg-50 slide hammer IIRC
a clamshell puller would make it easier, also available at a good rental centre
if you arent to deep into it now I would be tempted to run it
worse case the syncros will be worn and you have to match rpm on gear changes a bit closer
harder then a 205 but still pretty easy to play with, ask Dan
I say just run it. If it's just surface rust and not something that has been sitting in a pond filling with mud for 16 years. Just change the oil after a week's use to make sure there's no loose metal or rust residue left after all that crap lets loose. I'm a hack though, so do what you think is best /forums/images/graemlins/hack.gif
Not sure that they all do, but the 465 that is apart in my garage has a stock magnet at the bottom of the case for just such an occasion. /forums/images/graemlins/thumb.gif
I'd run it too, do some cursory checks to make sure there isn't anything obviously broken (rotate it, put it into all the gears) then drop it in.
That sounds really good to me. All the gears look real nice and it rotates real easy. I guess I just need a top cover gasket and a couple of PTO gaskets. I think my shift lever is a little bent from where it fell out of the truck /forums/images/graemlins/blush.gif. What's the best way to straighten it? Heat and bend?
Drop it the opposite way out of the truck so It bends back to normal /forums/images/graemlins/waytogo.gif
[ QUOTE ]
[/ QUOTE ]
agreed /forums/images/graemlins/yikes.gif
/forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif That would require driving that POS again, but only backwards, down that same hill and hitting the brakes in just the wrong spot so it would slide out of the truck bed past the open tailgate and almost hit my wife's car /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif Now would be some $^!T.
State Farm Agent: So, Mrs. Stansbury, how did this happen?
Wife: Well I was following my husband home as he was driving his brand new POS. The wiring shorted out and killed the truck. When he got it started he nailed it and shot the whole $%#!ing mess out into the street and I ran it over.
Agent: Did you know you have a $2000 deductible when it come to running over Chevy parts with you Ford?
Wife: Stupid hair-brained scheming, no-good, so-and-so, bleep, bleep, bleepity...... /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
[ QUOTE ]
[/ QUOTE ]
No isn't that about the truth!! ROTF /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
[ QUOTE ]
[/ QUOTE ]
ROTFLMFAO /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
I'd run it...unless you see something that's obviously hashed it should be just fine. My SM 465 has close to 300,000 miles on it and it's just starting to get a little crunchy if I shift too quickly.
For the shifter, remove it first then put it in a vice near the bent area. Heat it up til it's a dull red and pull it straight. You might want to try and bend it back cold...but that'll be a tall order, you'll most likely make it worse. The only drawback to heating it is ruining the chrome if it's a chrome shifter.
Rene
[ QUOTE ]
[/ QUOTE ]
Cool, thanks, I'll just do the seals, fill her up, run it for a while, and then change the oil again.
[ QUOTE ]
[/ QUOTE ]
Good thought. It is chrome, but I am sticking it in a flat tan military truck, so I'll just spray bomb it after I am done./forums/images/graemlins/thumb.gif
I'd make sure that it is bent in a way that it wasn't before first. I have a picture of one on my "home page" if you want to check it out. It's the taller of the two. There is also a tech article on the main page about a tranny swap that might have a picture.
