M monsterbowtiev8 Newbie Joined Dec 13, 2009 Posts 4 Reaction score 0 Location selah Jan 7, 2010 #1 does anyone sell a drive kit for a winch...running a pto drive off a 465
sweetk30 Back to play nice . Premium GMOTM Winner Joined Nov 1, 2004 Posts 43,005 Reaction score 25,455 Location in the back of your brain Jan 7, 2010 #2 local drive shaft shops or big truck parts stores will be good. and ebay has some also. few things to look for first tho. verify 100% on used one if from a sm465. were will winch be? front or rear of truck. is it front or rear output pto? you cant flip some . and will be stuck with what it is. and if rear it can only be on the other side of the front tcase output. like pass drop tcase would be driver side pto rear use only. and vise versa. then make sure you have room for a drive shaft up threw the under side of the truck if you are not using a hydrolic pump setup pto. lots to look out for. good luck.
Z ZukiJohn 1/2 ton status Joined May 29, 2007 Posts 215 Reaction score 1 Location Apache jct Az Jan 19, 2010 #3 Pto PTO SALES in Phoenix Az set mine up with the right gear and gasket's. They had everthing in stock,, Just need tranny #'s and pto #'s...
