SM465 questions
JK5
Norton, Oh
I searched...
Can you mount a np 205 to a sm 465 that's from a 208 combo...
Are the output shafts different on the sm465?
Thanks in advance.
J
From what I know, the SM465/208 had a 32 spline input/output.
The newer 205s, with round bolt pattern such as off of a th400 has a 32spline input. So yes, those will work.
However if you have an older 205 or older SM465 they will/can have 10spline input/outputs.
If that be the case, there is no way to mate them. Because the 32 spline output is long enough to go straight into the case, thus eliminating a coupler and or adaptive coupler.
I went down that route once, and was dissapointed. It is possible to change a 205 to the 32spline input, but it requires custom machinging and bearings.
Yes, you can. The factory did it from 1985-91. You need a round pattern NP205, which is relatively easy to find, and the adapter, which is very scarce.
Thanks guys!!! :D
Yes, it's the 32 spline shaft...
I guess I'm keep this for a spare trans for my 1 ton tow rig.
