estrugo
Registered Member
Hi,
I found a lot of info on automatic trannys and how to install the trans temp sender, but nothing on a manual SM465
I have an Autometer Pro Comp gauge that is still not installed (it's on the dash, but not connected yet)
I saw in the transmission that there is an oil filler plug and an oil drain plug, is it OK if I install the sender in the Oil filler plug? of course I will have to find the way to change oil from the drain plug when needed...
Any advice?
Any advice?
