OK I admit it, I don’t know a whole lot about these engines. I’m a diesel guy, I’ve never built a small block, I’ve never dealt with having to set timing on one or any of that shit. But at work I am building an 84 CJ7 with a hot rod company 355 in it. We got it running yesterday and during our initial break in run we found that it’s leaking oil from the distributor gasket and the headers started glowing. I had to turn the distributor counterclockwise as far as I could to get the thing to even start so I’m wondering if I’ve got the distributor one tooth off and the timing is what’s causing the exhaust to glow. Also, I was wondering if the length of the distributor shaft is adjustable. If there’s a set screw holding the gear on to the end of the shaft and I can slide it up a little and effectively shorten the distributor that should get it to seat all the way against the manifold and stop leaking. I haven’t pulled it back out to see if that’s even possible I figured I’d ask the gurus as I’ve got a couple ring and pinion jobs to do, it’s leaving to get exhaust built and won’t touch the CJ again till probably Monday.
